Programming Reference:SpellerCommand Class
src/shared/modules/application/speller
A SpellerCommand object represents a speller command in parsed form. Speller commands are either plain text, or command keywords and arguments enclosed in angle brackets:
a
Alpha
<UNDO>
<GOTO 3>
SpellerCommand(string)
Parses the argument string, and initializes the object's properties from there.
ReadFromStream(istream), WriteToStream(ostream)
Reads/writes the object from/into the specified stream objects.
string Code (rw)
For plain text entry commands, this property is empty. For keyword commands, it contains the keyword, e.g. "GOTO".
string Value (rw)
For plain text entry commands, this property contains the text to enter. For keyword commands, it contains arguments, if any, e.g. "3" for "<GOTO 3>".
Programming Reference:Speller Class, Programming Reference:Target Class, User Reference:P3SpellerTask
