Contributions:FnirsiUSBLogger
FNIRSI FNB58 USB Power Meter
A logger that stores voltage, current, and temperature readings from an FNIRSI FNB58 USB Power Meter into BCI2000 states. The FNB58 is able to measure voltage and current for USB-A, USB-C and Micro USB outlets in real time. For this, it hooks into a USB connection between host and any USB device for which to measure current draw and power consumption.
http://www.bci2000.org/svn/trunk/src/contrib/Extensions/FnirsiUSBLogger
mellinger@neurotechcenter.org
  • 2026/02/02: Initial public release
  • Initial development: 9245
  • Known to compile under: 9247
The FNB58 is an USB power meter and hooks into the USB connection between the host and a target USB device. To the host, it appears as a HID USB device and can be read out without a dedicated driver, using the Windows HID library.
The logger reads out the data provided and stores them in BCI2000 event states.
LogFnirsiUSB
This is the enabler parameter. Set it to 1 from the command line when starting the source module, or enable it in enabler list in BCI2000Launcher.
FnirsiUSB_Voltage
The USB bus voltage, with an offset of 2^31, and a scale of 1e-5 V.
FnirsiUSB_Current
The USB bus current, with an offset of 2^31, and in units of 1e-5 A.
FnirsiUSB_Power
The USB bus power, with an offset of 2^31, and in units of 1e-5 W.
FnirsiUSB_DataPlus, FnirsiUSB_DataMinus
Voltages on the USB transmission lines, with an offset of 2^15, and in units of 1e-3V.
FnirsiUSB_Temperature
Temperature as measured by the FNB58 device, with zero offset, in units of 0.1°C.
