Compiling error, can't find file
rebekahw
Post by rebekahw » 14 Jul 2009, 16:11
I am trying to compile the code in Borland Builder 2007 but I am unable to locate the file gUSBamp.h. I might be overlooking something obvious but I've been looking for awhile now and I can't find it. Could you please direct me to it's location?
Thanks in advance,
Rebekah
Post by jawilson » 15 Jul 2009, 08:34
It should be located in BCI2000/src/extlib/gtec/gUSBamp.
If you are compiling with Borland 2007, then all of the paths should be set correctly already. When/how did you download the source code?
Thanks!
Adam
rebekahw
Post by rebekahw » 15 Jul 2009, 14:52
I've been downloading it over the past week file by file but I only downloaded the ones required by the BCI2000.bpg and all the files for the Measurement Computing DAQ. Is there a quicker way?
Thanks for your patience,
Rebekah
Post by jawilson » 15 Jul 2009, 15:20
Rebekah,
There is a MUCH easier and preferred way! Check out this page:
http://www.bci2000.org/wiki/index.php/P ... e:Contents
and particularly this page:
http://www.bci2000.org/wiki/index.php/P ... ient_Setup
This tells you how to download BCI2000 source files, and compile them, etc.
Adam
rebekahw
Post by rebekahw » 15 Jul 2009, 16:26
Adam,
MUCH easier was an understatement!
Thanks so much,
Rebekah
