Programming Reference:Contents
This part of the reference provides background information which you need in order to understand, modify, or create code that depends on the BCI2000 framework.
You should read it before writing your own BCI2000 module, or modifying an existing one as presented in the tutorial examples.
[edit]
Getting Started
- Programming Howto:Quickstart Guide
- Programming Howto:Building BCI2000
- Programming Howto:SVN Client Setup
- Programming Howto:Using TortoiseSVN
- Programming FAQ
[edit]
Conceptual Overview
- Programming Reference:Filter Chain
- Programming Reference:Class Hierarchies
- Programming Reference:Signals
- Programming Reference:Error Handling
- Programming Reference:Localization
- Programming Reference:Rapid Development
- Programming Reference:Build System
[edit]
Programming Interface Documentation
[edit]
Generic Filter Interface
- Programming Reference:GenericFilter Class
- Programming Reference:Environment Class
- Programming Reference:GenericVisualization Class
[edit]
Text Messages
- Programming Reference:Errors and Warnings
- Programming Reference:Debug Output
- Programming Reference:LogFile Class
[edit]
Data I/O
- Programming Reference:GenericFileWriter Class
- Programming Reference:GenericADC Class
- Programming Reference:BCI2000FileReader Class
[edit]
Signal Processing Modules
[edit]
Application Modules
[edit]
Feedback Applications
[edit]
Stimulus Presentation/ERP Spelling Applications
- Programming Reference:StimulusTask Class
- Programming Reference:Stimulus Class
- Programming Reference:Target Class
- Programming Reference:AssociationMap Class
- Programming Reference:Speller Class
[edit]
Visual Output
- Programming Reference:GraphDisplay Class
- Programming Reference:GraphObject Class
- Programming Reference:3D API
[edit]
Audio Output
- Programming Reference:MidiPlayer Class
- Programming Reference:WavePlayer Class
- Programming Reference:TextToSpeech Class
[edit]
Miscellaneous
- Programming Reference:TrialStatistics Class
- Programming Reference:BlockRandSeq Class
- Programming Reference:RandomGenerator Class
- Programming Reference:EnvironmentExtension Class
[edit]
Tutorials
- Programming Tutorial:Implementing a Data Acquisition Module
- Programming Tutorial:Implementing a Signal Processing Filter
- Programming Tutorial:Implementing a Matlab-based Filter
- Programming Tutorial:Working with the FieldTrip buffer
- Programming Tutorial:Implementing another Matlab-based Filter
- Programming Tutorial:Implementing an Input Logger
[edit]
