P300Speller
Hiba_AZIZ
P300Speller
Post by Hiba_AZIZ » 27 Feb 2013, 03:04
Hi, I have qst plz
I read article talk about bci & home appliance ... & I want to realise the same work to controle a domotic home by using a 4x4 matrix that allowed a total of N=8 stimulus classes.
and in the middle of this matrice I want to put a fixation cross.... The fixation cross was static in the middle of
interface and never flashing, also during stimulation. how can do that????? :shock:
they said: " An asynchronous operating mode was implemented within the BCI2000 framework"
my qst is : how they do that ... i don't understand anythings :oops:
plz help me to found a solution
thank you
:wink:
stimulation interface composed of several icons... stimuli consisted in an intensificatin of rows and columns. a no flashing fixation cross was placed in the center of the screen
Re: P300Speller
Post by mellinger » 11 Mar 2013, 11:03
The GazeMonitorFilter can do that for you:
http://www.bci2000.org/wiki/index.php/C ... itorFilter
If you don't fully understand the content of a scientific article, you might proceed as follows:
* Ask your supervisor to translate the difficult sentences into your native language.
* Use Google/Wikipedia to learn about the meaning of words that you don't know, or which don't make sense to you in the meaning that you know.
* Use Google Scholar to search for scientific BCI articles that have such a word in their title.
* Then, read the paper again. Actually, the authors should have described how they implemented the "asynchronous operating mode," or they should provide a reference to a description elsewhere.
* If for some reason you think you really need to reproduce the authors' experiment, write to the one who is marked "corresponding author," and ask whether you may obtain a copy of the source code and other files used to implement the experiment.
Hiba_AZIZ
Re: P300Speller
Post by Hiba_AZIZ » 14 Mar 2013, 04:13
Dear Juergen
Hi
thank you for your reply to my question, it's okay I found it how can I put the fixation cross in the middle :D
But now I need To implement an asynchronous mode, it is implemented for the classifier
The asynchronous mode is implemented within the P300Speller application and it modifies the Classifier pipe, providing the asynchronous feature. Instead of waiting for the end of the trial to look for the winner symbol, the asynchronous classifier looks for the higher score value both for row and column classes and compares these values to the corresponding threshold values. If thresholds are exceed a classification occurs before the end of the trial, adapting the number of stimuli repetitions to the current user's state.
my question is:
How can I implement this ? should be modify the source code of P300Speller for implementing or what? it's alittle bit not obvious for me
because I'm beginning in this field.... I don't have a lot of experience within
:wink:
thank you another time
Regards
Hiba_AZIZ
Re: P300Speller
Post by mellinger » 19 Mar 2013, 11:19
when thinking about your question how to add the "asynchronous" mode to P3Speller, it turned out that it would be more difficult to explain how to do it than to do it myself.
So the current SVN version of the P3Speller supports asynchronous operation. To use it, first configure P3Speller in the standard way.
Then, change parameter settings as follows:
EpochsToAverage: 1
NumberOfSequences: 1
AccumulateEvidence: 1
MinimumEvidence: 2
You may need to experiment a bit in order to determine the optimum value for the MinimumEvidence parameter. If it is too low, selections will happen even if the subject is not paying attention. If it is too high, a very large number of stimulus repetitions will occur before a selection is made.
For background information about the MinimumEvidence parameter, see
http://www.bci2000.org/wiki/index.php/U ... umEvidence
Hiba_AZIZ
Re: P300Speller
Post by Hiba_AZIZ » 25 Mar 2013, 06:38
Hi Sir
but I have some questions related to tortoiseSVN:
you said:" the current SVN version of the P3Speller supports asynchronous operation". I didn't understand until now the relation between the Tortoise SVN & the P300Speller ? and how can I use it with the P300Spller application?
you also said:" change parameter settings as follows:
EpochsToAverage: 1
MinimumEvidence: 2"
I didn't found this parameter in P300Speller application!! or I will be find it in the source code of P300speller ?!!!
please can you explain that for me, because this my first time when I heard by the existing of TortoiseSVN
thank's another time
regards
Hiba_AZIZ
Hiba_AZIZ
Re: P300Speller
Post by Hiba_AZIZ » 08 Apr 2013, 03:40
hi again
plz Mr.Juergen can you give me reply to my question.... I am s late .. and should be do something
regards
tank you again
Re: P300Speller
Post by boulay » 08 Apr 2013, 10:09
A SVN server is a convenient way to manage source code.
Tortoise SVN is just a client for exchanging code with a SVN server.
Tortoise SVN has nothing to do with BCI2000 except that it will help you download the source code. There are other SVN clients out there, but Tortoise SVN is probably the best one on Windows.
I think what Juergen meant was that to use the new software that he made, you will have to download the latest source code then compile it. For instructions on how to download the code, see here:
http://www.bci2000.org/wiki/index.php/P ... ource_Code
For instructions on how to compile the new code, see here:
Hiba_AZIZ
Re: P300Speller
Post by Hiba_AZIZ » 10 Apr 2013, 09:06
Thank you so much Mr.boulay for your reply :)
Hiba_AZIZ
Re: P300Speller
Post by Hiba_AZIZ » 10 Apr 2013, 11:11
Hi again
please I have question
when can I find this parameters settings exactly because I see in the P3speller application and I didn't found it
AccumulateEvidence
MinimumEvidence
thanks again
Regards
Hiba_AZIZ
Re: P300Speller
Post by gschalk » 11 Apr 2013, 11:28
You will have to download the most recent source code using TortoiseSVN, and compile it.
