Dear all,
I have recently started working with EEG and I was using g.tec usbAMP and BCI2000. The laptop that came from g.tec at the time had everything installed and had windows 7 on it.
We recently updated that laptop to windows 10 and now BCI2000 seems to not recognize usbAMP. I am having this exact same issue that is posted before but none of the solutions have worked for me. I tried and updated all the drivers and everything but can't get this issue resolved.
viewtopic.php?t=1324
BCI2000 can not see the g.USBamp
Re: BCI2000 can not see the g.USBamp
it could be that you have a 32-bit executable and installed 64-bit drivers in the Windows 10 system, whereas in the Windows 7 system you had installed 32-bit drivers.
You might try downloading BCI2000 from here: https://www.bci2000.org/mediawiki/index ... ersion_3.6
and see whether it works with your drivers.
fatihbaha
Thank you very much for your reply and actually latest update solved this issue but now I am facing a new issue. BCI2000 recognizes the usbamp yet the moment I click set config it gives an error saying "Lost connection to Signalsource". Kind of similar to the issue talked about under this discussion but I am not trying to create any module viewtopic.php?t=3405
Please see attached screenshots
- BCI2000 issue first ss.png (137.67 KiB) Viewed 43585 times
- BCI2000 issue second ss.png (75.25 KiB) Viewed 43585 times
It appears that either somehow you are mixing executables from different distributions, or that your distribution is broken.
Have you tried compiling from source?
