hello,
I am trying to compile the project for the first time using CodeGear
but it gives me this error
[BCC32 Error] Unit1.cpp(295): E2285 Could not find a match for 'EncodedString::EncodedString(wchar_t *)'
in many sentences from line 290 and later
the same error also appeared while compiling other projects like operat.exe and BCI2000FileInfo.exe
any ideas??
Thanks in advance
Joe
Compiling Error
Compilation Error
Joe,
Which version of CodeGear are you using? Please download the most recent version of BCI2000 from SVN and try again.
Joe
Re: Compilation Error
I am using CodeGear C++ Builder 2009gschalk wrote:Joe,
I downloaded the whole src folder again and it gives me the same error
Joe
code
Joe,
What are you trying to do? I assume you have seen the programming tutorials on the bottom of this page:
http://www.bci2000.org/wiki/index.php/P ... e:Contents
Manuel
Hello Gerv
I started the tutorial in order to Compile BCI2000 with SigfriedSigProc.
I removed the # character in the makefiles File.
but when I built BCI2000 (command [i]make all[/i])
I got 2 errors:
**deleting obj\MatlabWrapper.obj
** deleting cmdline
(I used Delphi_C++Builder2009_ESD_June2009).
Since it was not working with this command line, I tried using directly CodeGear C++Builder. I got (in the MatlabSignal Processing):
[BCC32 Error] matrix.h(329): E2176 Too many types in declaration
the corresponding line is:
typedef CHAR16_T char16_t;
It is the first time I am using a compiler ... I dont know what is wrong,
could you help me ?
Thanks in advances
Manuel
I got 2 errors:
** deleting cmdline
could you help me ?
Thanks in advances
Manuel
