Hi
I want to use NI Elvis II for data acquisition (using its A/D converters), could you guide me how can I build a module for its interface with BCI2000?
Muhin
How to use NI Elvis II for Data Acquisition
NI
If this device is supported by the NI 6.9.x drivers, you can use it with the BCI2000 source module for those drivers. If it is supported by the newer MX drivers, there is a source module for that as well. If this is an old device that is supported by neither drivers, you can write a source module for it yourself as described here:
http://www.bci2000.org/wiki/index.php/P ... ion_Module
also see
http://www.bci2000.org/wiki/index.php/C ... tions:ADCs
also see
