Programming Tutorial:Implementing a Data Acquisition Module
Data acquisition modules are factored into
  • code required for any hardware, and
  • code required to access a specific hardware.
You provide only specific code. This is in a function that waits for and reads A/D data (line 3 in the pseudo code shown at Technical Reference:Core Modules), together with some helper functions that perform initialization and cleanup tasks. Together these functions form a class derived from GenericADC.
Example Scenario
Your Tachyon Corporation A/D card comes with a C-style software interface declared in a header file "TachyonLib.h" that consists of three functions
#define TACHYON_NO_ERROR 0
int TachyonStart( int inSamplingRate, int inNumberOfChannels );
int TachyonStop( void );
int TachyonWaitForData( short** outBuffer, int inCount );
From the library help file, you learn that TachyonStart configures the card and starts acquisition to some internal buffer; that TachyonStop stops acquisition to the buffer, and that TachyonWaitForData will block execution until the specified amount of data has been acquired, and that it will return a pointer to a buffer containing the data in its first argument. Each of the functions will return zero if everything went well, otherwise some error value will be returned. Luckily, Tachyon Corporation gives you just what you need for a BCI2000 source module, so implementing the ADC class is quite straightforward.
Writing the ADC Header File
In your class' header file, "TachyonADC.h", you write
#ifndef TACHYON_ADC_H
#define TACHYON_ADC_H
#include "GenericADC.h"
class TachyonADC : public GenericADC
 public:
   TachyonADC();
   ~TachyonADC();
   void Preflight( const SignalProperties&, SignalProperties& ) const;
   void Initialize( const SignalProperties&, const SignalProperties& );
   void Process( const GenericSignal&, GenericSignal& );
   void Halt();
 private:
   int  mSourceCh,
        mSampleBlockSize,
        mSamplingRate;
#endif // TACHYON_ADC_H
ADC Implementation
In the .cpp file, you will need some #includes, and a filter registration:
#include "TachyonADC.h"
#include "Tachyon/TachyonLib.h"
#include "BCIError.h"
using namespace std;
RegisterFilter( TachyonADC, 1 );
From the constructor, you request parameters and states that your ADC needs; from the destructor, you call Halt to make sure that your board stops acquiring data whenever your class instance gets destructed:
TachyonADC::TachyonADC()
: mSourceCh( 0 ),
  mSampleBlockSize( 0 ),
  mSamplingRate( 0 )
  BEGIN_PARAMETER_DEFINITIONS
    "Source int SourceCh=        64 64 1 128 "
        "// this is the number of digitized channels",
    "Source int SampleBlockSize= 16 5 1 128 "
        "// this is the number of samples transmitted at a time",
    "Source int SamplingRate=    128 128 1 4000 "
        "// this is the sample rate",
  END_PARAMETER_DEFINITIONS
TachyonADC::~TachyonADC()
  Halt();
ADC Initialization
Your Preflight function will check whether the board works with the parameters requested, and communicate the dimensions of its output signal:
void TachyonADC::Preflight( const SignalProperties&,
                            SignalProperties& outputProperties ) const
  if( TACHYON_NO_ERROR != TachyonStart( Parameter( "SamplingRate" ), Parameter( "SourceCh" ) ) )
    bcierr << "SamplingRate and/or SourceCh parameters are not compatible"
           << " with the A/D card"
           << endl;
  TachyonStop();
  outputProperties = SignalProperties( Parameter( "SourceCh" ),
                          Parameter( "SampleBlockSize" ),
                          SignalType::int16 );
Here, the last argument of the SignalProperties constructor determines not only the type of the signal propagated to the BCI2000 filters but also the format of the dat file written by the source module.
You might want to write SignalType::int32 or SignalType::float32 instead if your data acquisition hardware acquires data in one of those formats.
The actual Initialize function will only be called if Preflight did not report any errors. Thus, you may skip any further checks, and write
void TachyonADC::Initialize( const SignalProperties&, const SignalProperties& )
  mSourceCh = Parameter( "SourceCh" );
  mSampleBlockSize = Parameter( "SampleBlockSize" );
  mSamplingRate = Parameter( "SamplingRate" );
  TachyonStart( mSamplingRate, mSourceCh );
Balancing the TachyonStart call in the Initialize function, your Halt function should stop all asynchronous activity that your ADC code initiates:
void TachyonADC::Halt()
  TachyonStop();
Data Acquisition
Note that the Process function may not return unless the output signal is filled with data, so it is crucial that TachyonWaitForData is a blocking function. (If your card does not provide such a function, and you need to poll for data, don't forget to call Sleep( 0 ) inside your polling loop to avoid tying up the CPU.)
void TachyonADC::Process( const GenericSignal&, GenericSignal& outputSignal )
  int valuesToRead = mSampleBlockSize * mSourceCh;
  short* buffer;
  if( TACHYON_NO_ERROR == TachyonWaitForData( &buffer, valuesToRead ) )
    int i = 0;
    for( int channel = 0; channel < mSourceCh; ++channel )
      for( int sample = 0; sample < mSampleBlockSize; ++sample )
        outputSignal( channel, sample ) = buffer[ i++ ];
  else
    bcierr << "Error reading data" << endl;
Adding the SourceFilter
Most measurement equipment comes with hardware filters that allow you to filter out line noise. For equipment that does not offer such an option, consider adding the SourceFilter to your data acquisition module as described here.
Finished
You are done! Use your TachyonADC.cpp to replace the GenericADC descendant in an existing source module, add the TachyonADC.lib shipped with your card to the project, compile, and link.
