Template:LoadConfig
Appearance
(Redirected from Template:ConfigureSystemSpecificParameters)
- In the configuration window, click "Load Parameters", and load the system-specific parameter file saved previously at parms/fragments/<YourSystem>.prm.
- Again, click "Load Parameters" to load {{{paramfile}}}.
- When you have a separate monitor for experimenter and subject, load the parameter file at parms/fragments/stdlib/DualMonitor.prm.
- In your system's display properties configuration, make sure that the subject's monitor is configured to be located to the right of the main monitor.
- Make sure the WindowLeft parameter matches the main monitor's actual pixel width.
- You may need to adapt WindowTop, WindowWidth, and WindowHeight parameters as well; click "Set Config" to try the effect of your changes.
