undefined function 'load_bcidat'
Sabrina Walter
Post by Sabrina Walter » 04 Feb 2011, 08:04
dear all,
I get the following error message when trying to import dat-files with eeglab, although BCI2000 EEGlab-Import is installed:
eeglab error in function BCI2000import() at line 27: Undefined
command/function 'load_bcidat'.
Could you please help me with it?
Many thanks in advance,
Sabrina
Post by mellinger » 04 Feb 2011, 08:22
Hi Sabrina,
you need to manually add the BCI2000 tools/mex directory to your Matlab path. Then it should work.
Sabrina Walter
Post by Sabrina Walter » 07 Feb 2011, 06:47
Hi Juergen,
thanks for the quick reply. I tried various matlab version since then (e.g. 7.5 and 7.7) but it still did not work. I did what you recommended and then had the other error message
'there is no load_bcidat mex for your plattform available'
similarly to the one documented in the forum here. When I tried to act like described there, at the buildmex step it failed again.
You would make me very happy, if you could help me.
Many thanks,
Sabrina
Post by mellinger » 07 Feb 2011, 08:22
Sabrina,
what operating system are you using? When trying the buildmex step, how does it fail?
Sabrina Walter
Post by Sabrina Walter » 07 Feb 2011, 08:43
Hi Juergen,
I am using windows xp 2002, and the error message (in this case generated with matlab 7.1 and 7.5) is this:
??? Undefined variable "CXXFLAGS" or class "CXXFLAGS".
Error in ==> buildmex at 189
mex( options{:}, CXXFLAGS{:}, LDFLAGS{:}, INCLUDEPATHS{:}, DEFINES{:}, [target '.cpp'], MEXSRC{:} );
Error in ==> buildmex at 141
buildmex( options{:}, TARGETS{i} );
Thanks again,
Sabrina
Post by mellinger » 07 Feb 2011, 09:32
Hi Sabrina,
it appears you have an outdated version of the BCI2000 source code. Please update to the current SVN version, and try again.
