P300 Classifier Error
nadu
Hello !
I am getting the following error when I am running the P300 Classifier
Signal must have rows > cols. Linear classifier is valid only for overdetermined systems.
I did not understand the message. Is it something to do with my parameter files?
Can anyone please tell me what mistake I might be making?
nadu
nadu
cmpotes
This message means that in your training data set you have less training samples (n) than variables (p). Therefore, the P300Classifier is not able to solve the linear system Ax=b through the stepwise linear discriminant algorithm because the matrix A (n = samples by p = variables) has n<p.
To solve this problem, you should include more training samples in your data.
Hope it helps!
Hope it helps!
nadu
Thanks, one more question
Thank you Cristhian !
I used 4 data files of the subject when he was trying to spell the words - THE, QUICK, BROWN, FOX
The prediction accuracy came out to be 8% only. I did not screen the subject for the presence of a P300 response. Do I have run the data files through the P300 GUI (the Matlab program) to screen for a P300 response?
Is there any other recommended way/application to screen if a subject has a P300 response?
nadu
nadu
nadu
Hi !
I tried running 2 different subjects through the P3Speller. The procedure that I followed was -
1) Run the subjects through the words THE, QUICK, BROWN, FOX. Run the collected 4 data files through the P300 Classifier with the following p300Classifier.ini file
3) P300Classifier generated the parameters which I appended to my original parameters file.
4) Then I gave the subject 2 sentences to spell - in online free mode
HOW ARE YOU
I AM FINE
Both the subjects could hardly spell a letter correctly.
What might be the mistakes that I must watch out for ?
Can it be a problem with the Parameters that I am setting?
How do I guess the channels for the subject initially?
Whats the best accuracy that the P3Speller gives?
The parameter and the data files are at http://naduism.com/BCI_Data
Would be great if you can give me some pointers/ideas on how to fix this.
nadu
[Initialization]
maxiter = 60 // to set Max Model Features
penter = 0.1000 // to set Penter
premove = 0.1500 // to set Premove
spatial_filter = 2 // to set Spatial Filter. Set 1 for RAW and 2 for CAR
decimation_frequency_Hz = 20 // to set Decimation Frequency
channel_set = 1 2 3 4 5 6 8 9 11 13 14 15 16 // to set Channel Set
Resp_window_ms = 0 800 // to set Response Window. The response window must be in milliseconds (ms)
HOW ARE YOU
I AM FINE
nadu
P300Classifier
Nadu,
What was the accuracy (shown by P300Classifier) when run on the data files offline? If this is good, but you did not achieve good performance online, then there is some problem with loading the updated classifier back into BCI2000. (You should load that parameter file after loading the standard parameter file, not simply append to it. If you have two parameters with different values in the same parameter file, I am not sure which one BCI2000 would use.)
If you get bad performance also offline, then there is a problem with the data collected.
nadu
Hello !
I had given the text to spell for the subject 2 as "LETS_GO_HOME".
The answer shown by the classifier (image below) is pretty close (RETS_GO_HOME) but the %correct is 0. Can you advise where I might have gone wrong.
The data file that I am using for the testing -
http://naduism.com/BCI_Data/subject_2_R08.dat
after training on -
http://naduism.com/BCI_Data/subject_2_R01.dat
http://naduism.com/BCI_Data/subject_2_R02.dat
http://naduism.com/BCI_Data/subject_2_R03.dat
http://naduism.com/BCI_Data/subject_2_R04.dat
nadu
after training on -
nadu
cmpotes
Nadu,
Could you send me your data to cmpotes@miners.utep.edu ?
The P300Classifier should give you the correct percentage of classification. Let me check it.
cmpotes
Nadu,
In the latest version of the P300Classifier, this is what I got when I test on
Flashes % Correct Predicted Symbols
1 0 LMJ3TLV8KOHY
2 0 LBJWTFD11RKM
3 0 LBITTLJ11RU4
4 0 LKOT4LPOIOHF
5 0 LGOW4HPOOPBF
6 0 LAQT4LGMIOBF
7 0 LEIW4FGGIOBF
8 0 _DOT4LGIIOBF
9 0 FEKT4LJIIOE4
10 0 FEKT4LJGIOH4
11 8 FEIT4LPRIOHF
12 8 FEIT4LORIOHF
13 8 FEOT4HPRIONF
14 8 FFOT4HPRIPEF
15 8 FEOTRHPRIONF
Done!
Time elapsed [s]: 13
I would suggest you to download the latest version from BCI2000.
Let me know if it works!
1 0 LMJ3TLV8KOHY
2 0 LBJWTFD11RKM
3 0 LBITTLJ11RU4
4 0 LKOT4LPOIOHF
5 0 LGOW4HPOOPBF
6 0 LAQT4LGMIOBF
7 0 LEIW4FGGIOBF
8 0 _DOT4LGIIOBF
9 0 FEKT4LJIIOE4
10 0 FEKT4LJGIOH4
11 8 FEIT4LPRIOHF
12 8 FEIT4LORIOHF
13 8 FEOT4HPRIONF
14 8 FFOT4HPRIPEF
15 8 FEOTRHPRIONF
Done!
nadu
Tried with latest version of P300
Hi Cristhian !
I downloaded the latest version of the P300 Classifier (rev 2981) from the trunk.
I am getting this as the output when I run the P300 with http://naduism.com/BCI_Data/subject_2_R08.dat
1 17 VWZ__UJLSXF8
2 33 UUZ_7SVUSX_D
3 25 VU4_7SV7YX_D
4 42 VU4L_UT7S__2
5 33 VU2H_UD7S__2
6 33 VUYH_UV7S__2
7 50 VUYH8UT7SX_2
8 58 TUGH8UT7SX_2
9 50 TUA_DUTOS__2
10 58 TUA4EOTOS__2
11 50 TUA4AUTOS__2
12 58 TU44SOTOS__2
13 67 TUG4AOTOSX_2
14 67 TUG4AOTOSX_2
15 75 TUF4AOTOSX_2
The ini file that I am using is
This is when I am using the above file as training data file and generating feature weights.
I was getting results in my previous post when I used the file R01-R04 as training files and the R08 as test data file.
Do let me know where I might be going wrong.
nadu
1 17 VWZ__UJLSXF8
2 33 UUZ_7SVUSX_D
3 25 VU4_7SV7YX_D
4 42 VU4L_UT7S__2
5 33 VU2H_UD7S__2
6 33 VUYH_UV7S__2
7 50 VUYH8UT7SX_2
8 58 TUGH8UT7SX_2
9 50 TUA_DUTOS__2
10 58 TUA4EOTOS__2
11 50 TUA4AUTOS__2
12 58 TU44SOTOS__2
13 67 TUG4AOTOSX_2
14 67 TUG4AOTOSX_2
15 75 TUF4AOTOSX_2
[Initialization]
Resp_window_ms = 0 800 // to set Response Window. The response window must be in milliseconds (ms) I was getting results in my previous post when I used the file R01-R04 as training files and the R08 as test data file.
nadu
faisal-awan
The current BCI2000 binary distribution may always be downloaded from
http://bci2000.org/downloads/bin/BCI2000Setup.exe
faisal-awan
