dsteines
Post
by dsteines » 18 Jun 2010, 17:57
I am using the SetFrequencies member of BlockRandSeq.h and encountered a bug. I am using v3.0 in VS 2008.
curElement should be initialized as Sequence::iterator instead of Sequence::const_iterator. Otherwise the function cannot write the sequence.
David
Post
by jawilson » 09 Jul 2010, 09:19
David,
Do you get a compilation error right now, or is the behavior of BCI2000 different from what you would expect?
Adam
Post
by mellinger » 12 Jul 2010, 08:57
David,
I confirmed this was a bug that would show up at compile time. It's fixed now.
Thanks for reporting,
