I'm working with bci2000 to process an EEG signal acquired with G-USBamp. What I have to do is to allow the interaction of a quadriplegic person with the room they live.
The problem I have is that I want the info from bci2000 to matlab. I'm using the local host with a UDP port where matlab will retrieve it. But it's not happening. The info does not go to matlab.
Do I need to make other specificationes besides the port where bci2000 should send the info?
bci2000-Matlab connection
Anita,
are you using the AppConnector protocol, or the P3Speller's UDP output?
In case of the latter, you might check this post:
http://www.bci2000.org/phpbb/viewtopic.php?p=1820#1820
for an example how to receive speller output in Matlab.
steven.b.smith
Anita,
I am doing the exact same thing! And I actually figured out how to do it the day you posted to this forum! I typed up a set of notes in PDF that can help you get started. Email me at sbs34@drexel.edu if you want them. They are very rudimentary, however, as I haven't created an automatic processes yet, and I am still working on the synchronization between matlab and BCI.
Also, who are you working with on this? I am working on a similar problem concerning ALS patients as my Senior Design Project at Drexel University in Philadelphia, PA.
steven.b.smith
AnitaB
Mellinger and steven.b.smith we're having this problem:
when we run the program mellinger gives us, the info is not read and get this on Matlab:
"Warning: A timeout occurred before the Terminator was reached"
It's like BCI2000 is not sending the info to the port.
The same happens when we run steven.b.smith's program. It's very similar to what Melliger gave
