Hello, I'm a newbie and while running through the tutorial I realized that, in my BCI2000Viewer window, I don't have the rightmost subwindow with the list of States and Channels that I should check/uncheck.
Why is this so?
Ernesto
BCI2000Viewer: don't see the States nor Channels sub-Window
Ernesto.Soares
Ernesto,
thanks for reporting this problem.
That subwindow should be always present, even if no file has been loaded.
In order to investigate the problem further, the following information would be helpful:
* Build information, as displayed above the "Close" button when choosing "Help->About...".
* Your operating system version.
Ernesto.Soares
Ernesto,
this is the executable from the October 2008 build, which works fine for me under WinXP Professional 2002 SP3.
You might try the following:
- - quit the viewer,
- run regedit and remove the key HKEY_CURRENT_USER/Software/BCI2000/VIEWER and all its subkeys,
- check whether the problem is gone.
