DOWNLOAD BCI2000
EliGC
DOWNLOAD BCI2000
Post by EliGC » 04 Aug 2008, 11:02
Hello, i tried to download the BCI 2000 source and when i clic on the items then appeared just the text of the .cpp files and others :( . This happened because i don´t have c++ Software? or what else can i do to solve this problem? because i want to have a files to reproduce or read with c++ builder (to modified the source code).
Thanks in advanced,
:D
Eli
Post by mellinger » 04 Aug 2008, 12:46
Eli,
you will need to install Borland's C++ Builder Version 6 or Version 2007 in order to build BCI2000 from its source code.
Once C++ Builder has been installed, double-click the file BCI2000/src/BCI2000.bpg in order to load all BCI2000 sub-projects into the Borland IDE. If the .bpg extension is not associated with the Borland IDE, then start the IDE from the Start menu, and open BCI2000.bpg using the IDE's File->Open menu entry.
Once BCI2000.bpg has been opened by the IDE, you will see a list of projects with their associated source files. Double-click source files from there to open them in the IDE's editor window.
For more details, please see this Wiki page:
http://www.bci2000.org/wiki/index.php/P ... w_to_build
EliGC
Post by EliGC » 04 Aug 2008, 15:36
Thanks for everything, i'm going to do all of these things.
Eli
