ActiChamp and BCI2000 new version
cmontilla
I am trying to use my ActiChamp amplifier with the new version of BCI2000 that I compiled (version 3.6.9546).
However, when I click "Set Config," I get the following error in Operator Module:
2026-09-15T11:22:32.253 - SignalSource warning, DataIOFilter::Resting: actiCHampBufferedADC::Process:
Data acquisition timeout.
2026-09-15T11:22:32.261 - SignalSource error:
Lost connection to SignalSource.
I am using the same parameter file as in version 3.6.7385, which is the one I used previously. (I have tried configuring the parameters manually, but the same error keeps appearing.)
Any suggestions are welcome.
Re: ActiChamp and BCI2000 new version
Thanks for your helpful bug report.
I found and fixed an issue that is related to your problem, but I could not test because I don't have an ActiChamp available.
Please update to the latest SVN version and recompile.
cmontilla
I try to test and I get the following error now:
2026-09-16T10:30:46.840 - Application: P3Speller initialized.
2026-09-16T10:30:50.388 - SignalSource error, actiCHampDevice::output_data:
Error in module 0.
Error in module 1.
Error in module 2.
2026-09-16T10:30:50.388 - SignalSource warning, DataIOFilter::Resting: actiCHampBufferedADC::Process:
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
2026-09-16T10:30:50.389 - SignalSource error, actiCHampDevice::output_data:
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
2026-09-16T10:30:50.390 - SignalSource error, actiCHampDevice::output_data:
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
2026-09-16T10:30:50.398 - SignalSource error:
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
Error in module 0.
Error in module 1.
Error in module 2.
Error in module 3.
Error in module 4.
Error in module 5.
It seems your ActiChamp device reports hardware errors.
Which ActiChamp model are you using?
Can you use the vendor software to make sure the device works as intended?
cmontilla
It is the 32-channel ActiChamp (not the Plus version).
I have used it, I have a program (BrainVision Pycorder) where I view the signal being recorded in real time, and the amplifier works correctly.
It works properly in BCI2000 version 3.6.7385.
The only thing is that I added the filter module exactly as explained here: (in BCI2000 version 3.6.7385 works)
https://www.bci2000.org/mediawiki/index ... urceFilter
It might be that you compiled BCI2000 in debug mode, whereas r7385 was built in release mode.
Certain bugs may show up in debug mode rather than release mode (and vice versa).
Could you rebuild the ActiChamp source module in release mode and try again?
cmontilla
Yes, I have rebuild in release mode, now I see the new error:
Short read, data will be invalid.
That's quite interesting, I didn't think this error message would be triggered.
I've expanded the message a bit, could you update and run again and report the expanded error messsage?
Thanks!
Thanks!
cmontilla
Of course!!
Short read, data will be invalid, requested: 2688, received: 0.
Thank you very much for your patience.
It might work now.
cmontilla
I'm getting the error again:
Could it be due to my .prm file? Although I get that error with the default configuration as well... (I try in release and debug mode)
You might experiment with different values of the SampleBlockSize parameter.
Could you provide me with the error message prior to "Lost connection to SignalSource"?
cmontilla
2026-09-18T12:08:28.688 - BCI2000 Started.
2026-09-18T12:08:29.069 - SignalProcessing: Waiting for configuration ...
2026-09-18T12:08:29.100 - SignalSource: Waiting for configuration ...
2026-09-18T12:08:29.186 - Application: Waiting for configuration ...
2026-09-18T12:09:54.480 - Operator set configuration.
2026-09-18T12:09:55.586 - SignalSource: ActiCHampSource initialized.
2026-09-18T12:09:55.596 - SignalProcessing: P3SignalProcessing initialized.
2026-09-18T12:09:56.355 - Application: P3Speller initialized.
2026-09-18T12:09:58.018 - SignalSource error:
I'm trying out other combinations to see if I can share some news soon.
Thank you very much.
I fixed another bug, maybe you want to give it a try.
cmontilla
I keep getting the same error in the Operator log in the release mode....
