Amplification of BCI2000 System EEG Signals
sgupta
Post by sgupta » 16 Sep 2004, 12:19
I have the dataset IIa from BCI Competition 2003. I would like to know that what will I have todo to get the absolute values of EEG signals in microVolts. I have read that the amplification used for this dataset was 20000. Does that mean simply dividing the signal values by 20000 would give me absolute values ?
Please help....
Conversion factor ...
Post by gschalk » 22 Sep 2004, 12:58
The numbers are in units of A/D units. The conversion factor to micro Volts is 0.008.
I hope this helps,
faisal1
Post by faisal1 » 17 Jun 2008, 17:32
hi gerv,
i have a dataset collected from the EEG machine having Fs=200hz, and amplication of 10000 . How i could the absolute value of EEG data.
Is their any const value to multiply , and if so How could we calculate it????
Regards
Faisal
data acquisition ...
Post by gschalk » 17 Jun 2008, 21:04
Faisal,
This completely depends on the bit resolution of your A/D converter and the input range of your A/D card/EEG system. The easiest thing is if you acquire a signal with a known amplitude, and then see how large it is. This will determine the conversion factor.
