problems with BCI2000Shell executable file
andy78lecce
Post by andy78lecce » 08 May 2025, 03:47
Hello, I am new to using the software and am attempting to configure its operation on an embedded platform (Raspberry - ARM64 processor). I am getting the following error when launching the shell: module OperatorLib.dll has an invalid executable format.
Could this be a compatibility problem with the ARM64 processor?
Thank you
Re: problems with BCI2000Shell executable file
Post by mellinger » 08 May 2025, 08:10
Hi, could it be that you compiled for a different architecture before? If so, compiling the entire solution in VisualStudio should fix the issue.
