cdocon
Post
by cdocon » 31 Jul 2014, 00:56
I'm building a filter where I want to be able to access values in the state vector, specifically the StimulusCode value when running the StimulusPresentation task as outlined in the Mu Rhythm Tutorial. At present, I am putting
in the filter's preflight function, and
int curStimulusCode = State("StimulusCode").AsUnsigned();
bciout << "StimulusCode: " << curStimulusCode;
in the Process function in an attempt to simply write the current stimulus code to the bci standard output. The result shown in blank, however in the .dat file the Stimulus Code is present. I was hoping someone could explain where I am going wrong and how best to access the state being presented to the user. If it helps, I am developing on Windows 7 under Visual Studio 2010 using revision 4736.
Thanks.
Post
by boulay » 31 Jul 2014, 09:56
Have you tried without the .AsUnsigned() ? Just looking through some BCI2000 core modules, I never see that used.
What if you try
bciout << "StimulusCode: " << State("StimulusCode");
Does that work?
cdocon
Post
by cdocon » 31 Jul 2014, 13:42
I tried but it did not make a difference. What is strange is that I even tried manually setting the state prior to reading like so:
State("StimulusCode") = 1;
int curStimulusCode = State("StimulusCode");
but the result is the same - simlpy outputting a blank value on the standard output:
To me this indicates that I am missing some particular read/write notation, but cannot find anything in the wiki.
Post
by boulay » 31 Jul 2014, 14:35
Obviously I don't know the answer. I'm just trying to help you work through it. Does the following work?
//int curStimulusCode = State("StimulusCode");
int curStimulusCode = 1;
Just to make sure bciout recognizes the int. I expect this to work, but if it does not then it would go a long way to helping to identify the problem.
Assuming that works, then what about
bciout << "StimulusCode: " << State("StimulusCode").Value();
Post
by boulay » 31 Jul 2014, 14:45
cdocon
Post
by cdocon » 31 Jul 2014, 17:49
Got it! Turns out bciout won't print the value to the standard output unless followed by an endl. What was confusing me was bciout would still print the string literal part. Your suggestion about trying a plain int is what put me on the right path, thanks for your help!
