TMSi 64 bit + BCI2000
malechka
Post by malechka » 19 Nov 2013, 08:41
We installed the new driver for the TMSi amplifier on a 64 bit system but the TMSi.exe for BCI2000 can not find the TMSi device. I read the posted topic to this issue on this forum:
http://www.bci2000.org/phpbb/viewtopic.php?f=9&t=2073
If I understood correctly, the available source on BCI2000 wiki uses RTINST.dll (RTDevice.ccp), which are not supplied by the new driver installation. The new driver installation uses TMSiSDK.dll
The last post was published in March 2013, maybe someone solved this problem and can help me.
Re: TMSi 64 bit + BCI2000
Post by mellinger » 25 Nov 2013, 09:24
we don't have any information about the current TMSi SDK. In case they just renamed the DLL, it would be quite easy to make the existing source module work, but that's rather unlikely.
In response to your post, I've asked TMSi for information about their current driver library. If I get a response, I will be able to add support for the current driver to BCI2000.
