UDP output
ageronimo
UDP output
Post by ageronimo » 17 Apr 2013, 17:45
I recently upgraded from 3.0.1 to 3.0.5 and can no longer connect to an external application through UDP (Dasher). I think I have tracked down the problem but am not sure how to solve it. Running the 3.0.1 version of the CursorTask_gUSBamp batch file, I get the following UDP input in the Dasher socket debugger.
Reading from socket...
 received string: 'ResultCode 0
 received string: 'Feedback 0
 received string: 'CursorPosX 0
Matched label 'CursorPosX'...
...parsed value as 0.000000.
Socket input: clipped CursorPosX value of 0to configured minimum of 205
Socket input: new value for coordinate 0 rescales to 4096 in Dasher's internal c
oordinates (range 0-4096).
Socket input: new value for coordinate 1 rescales to 0 in Dasher's internal coor
 received string: 'CursorPosY 0
 received string: 'CursorPosZ 0
 received string: 'Running 1
 received string: 'Recording 1
 received string: 'SourceTime 60013
 received string: 'StimulusTime 60019
 received string: 'Signal(0,0) -0.0953556
As opposed to the 3.0.5 version where i get:
 received string: 'PauseApplication 0'.
 received string: '
 received string: 'CursorPosX 0'.
 received string: '
 received string: 'CursorPosY 0'.
 received string: '
 received string: 'CursorPosZ 0'.
 received string: '
 received string: 'StimulusTime 7163'.
 received string: '
 received string: 'Signal(0,0) -8.00468'.
 received string: '
 received string: 'Running 1'.
 received string: '
 received string: 'Recording 1'.
 received string: '
 received string: 'SourceTime 7218'.
Both outputs have each state/signal separated by a return, but Dasher interprets them differently. How can I go about modifying this in the 3.0.5 version to be compatible with what Dasher expects to read?
Thanks in advance,
Andrew
ageronimo
Re: UDP output
Post by ageronimo » 17 Apr 2013, 20:26
Ok so I figured out a solution-- made the following changes to ConnectorFilters.cpp
int
ConnectorOutput::Connection::OnExecute()
  const int cReactionTimeMs = 100;
  while( !IsTerminating() )
    if( Wait( cReactionTimeMs ) )
      Reset();
      bool result = true;
      while( result && !IsTerminating() )
        string message;
          ::Lock<Connection> lock( *this );
          result = std::getline( *this, message );
        if( result && !IsTerminating() )
          //Used to Be
          //mSocket.write( message.c_str(), message.length() );
          //mSocket.write( "\n", 1 );
          // Changed for Dasher compatibility. AG 4/17/13
          message += "\n";
  return 0;
It works now, but is this the best way to do it? Is there another way to do this that doesn't have me modify the core BCI2000 code?
Andrew
Re: UDP output
Post by gschalk » 18 Apr 2013, 12:25
You are saying it worked in 3.0.1 and now does not work in 3.0.5 (before you made that change)?
ageronimo
Re: UDP output
Post by ageronimo » 20 Apr 2013, 11:42
Correct -- Dasher (version 4.1.1) was able to read the CursorPosX state over UDP when I was using BCI2000 3.0.1. When I upgraded to 3.0.5, Dasher was able to read the BCI2000 States, but my guess is that it the State outputs were formatted slightly differently and wasnt able to recognize that the CursorPosX variable had been sent. The change I made to ConnectorFilters.cpp was my attempt to put the UDP output in the exact format I was getting with 3.0.1. This seems to work now.
Re: UDP output
Post by mellinger » 29 Apr 2013, 09:27
thanks for reporting this problem. I was not aware there would be software out there that treated BCI2000's UDP output in form of individual packets, rather than a continuous stream of characters.
I fixed that issue in the current SVN version of BCI2000.
