hi
I have problem when I want configure BCI2000 with gMOBIlab+
erreur: " DataIOFilter::Preflight: gMOBIlabADC::Preflight: Could not connect to device at COM port COM7:."
when the default com port for gmobilab+ is COM7
how can I resolve this problem
Configure gtec with BCI2000 new version
Re: Configure gtec with BCI2000 new version
Did you try to use a different COM port? I.e., set the MOBIlab to a different COM port, and then configure BCI2000 for that port? I remember that there was some issue with high COM ports.
Also, are you using a serial connection or Bluetooth?
If you use Bluetooth, there are finicky issues with built-in Bluetooth stack vs. the Bluetooth stack provided by g.tec. Thus, if you use Bluetooth, you may try serial first.
Hiba_AZIZ
hi again
& Thanks for you response
we use the Bluetooth provided by g.tec.
and I don't know how can I configure it
regards
regards
Hiba_AZIZ
hi
tank you its work now
alanchiu2
Hello I am new to the Board and the BCI2000 software. I also encountered similar problem while using the g.MOBIlabPlus with BCI2000 for P3Speller.
"Could not connect to device at COM port COM10."
I tried changing the COM port to 1 and 2, and still doesn't work. Any suggestions would be welcomed. Thank you.
this is not a BCI2000 issue. Please use your gMOBIlabPlus manual in order to learn about associating a device with a certain COM port. Then, make sure that you can read data from that device using g.tec's demo/test software. If that succeeds, exit from the g.tec software, and use the same COM port for BCI2000 configuration.
