Is it possible to use BCI2000 script for the g.USBamp amplifier on a Ubuntu platform? I already have the g.USBamp Linux API C.
Thanks for your help.
Mauro
BCI2000 and g.USBamp on Ubuntu
Re: BCI2000 and g.USBamp on Ubuntu
You should just have to recompile the USBamp Source module with the Linux C library.
Sorry, but it's currently not possible to compile the gUSBamp Source module with the Linux C library but I can quickly fix this if you send me a private message containing the header file(s) coming with the Linux C library, to which I don't have access currently, and with the name(s) of any .so/.o/.a files being part of that library.
Providing the header file(s) without library files should not violate the API licensing terms, but if you have concerns in that respect, I'll ask gtec (which will take some more time probably).
m.bruno
Thanks for the informations!
If i need other help i recontact you.
Mauro
Mauro
