Error in User Tutorial:BCI2000 Tour:Mu Tutorial
Mahelita
Post by Mahelita » 23 Jan 2013, 07:54
Hi All,
just reporting that there is an error in the User Tutorial:BCI2000 Tour:Mu Tutorial ( http://www.bci2000.org/wiki/index.php/U ... I2000_Tour ) when using the lastest BCI2000 version (downloaded on 2012.01.22).
In the Parameter Files section, the user is told to load the parms/fragments/amplifiers/SignalGenerator.prm and parms/mu_tutorial/MuFeedback.prm parameter files but those files are actually wrongly configured and produce following error:
SpatialFilter::Preflight: The input signal's number of channels (4) must match the number of columns in the SpatialFilter parameter (8)
Not loading the parameter files after opening batch/CursorTask_SignalGenerator.bat solves the error.
It might be good to edit the wiki to remove the parameter loading steps.
Best,
Lukas
Re: Error in User Tutorial:BCI2000 Tour:Mu Tutorial
Post by mellinger » 23 Jan 2013, 15:44
thanks for the notification. The MuTutorial parameter file sets SpatialFilterType to CAR, so it should produce that error message.
Being able to reproduce the problem myself, I think this is a recent bug in BCI2000. I'll fix it ASAP.
