dmgongora
Post
by dmgongora » 01 Mar 2012, 21:51
Hi everyone,
I've a little question concerning the implementation of the CAR filter in the offline analysis tool. Concretely, the carFilt.m performs CAR filtering on the specified signal.
spatfiltmatrix=-ones(num_chans);
for i=1:num_chans
spatfiltmatrix(i, i)=num_chans-1;
end
signalOut=double(signal)*spatfiltmatrix;
However, by the end of the computations. Shouldn't the variable signalOut be divided by the number of channels? I mean, according to "A Practical Guide to Brain Computer Interfacing with BCI", the sum of the signal from all the channels(divided by the number of channels H) is substracted from the specified signal(s_h). But the matrix multiplication produces (H)s_h'=(H-1)s_h-SumOfTheRestOfTheChannels.
What am I missing?
Daniel
Post
by mellinger » 02 Mar 2012, 08:43
that computation was clearly wrong, I fixed it on SVN. Thanks for notifying!
As you point out, the result differed from correct CAR filtering only by a constant factor of H, such that r^2 statistics were still correct. Amplitudes themselves, however, were off by a factor of H.
