2D cursor movement using EEG signal
sonidaman
Post by sonidaman » 26 Jan 2012, 08:03
hello alll,
i m doing my project on 2D cursor movement using EEG for my masters project.i need help about that.i need all information and the EEG signal which i can use it for the processing in MATLAB.i need BCI2000 software also.please help me about my project :( .
Thnx in advance.
Re: 2D cursor movement using EEG signal
Post by mellinger » 30 Jan 2012, 08:57
To download BCI2000, first get a user account as described here:
http://www.bci2000.org/wiki/index.php/C ... er_Account
To learn how to perform 1D cursor movement, please follow this tutorial:
http://www.bci2000.org/wiki/index.php/U ... I_Tutorial
Before proceeding to 2D cursor movement, first establish 1D cursor movement using two different signals, e.g. 18Hz@C3+18Hz@C4, and 20Hz@Cz (frequencies are arbitrarily chosen for the example, and must be obtained from 1D analysis, electrodes correspond to both hands vs rest and feet vs rest).
Once your subject is able to control the cursor with each of these signals in 1D, you can move to 2D by associating the first signal with vertical movement, and the second signal with horizontal movement. Then, instruct your subject to use feet imagination to control the cursor horizontally, and hand movement imagination to control it vertically.
sonidaman
Post by sonidaman » 30 Jan 2012, 10:12
Thnx for your reply sir.
I have created my account here.
And For 1D cursor i dont know from where i should start to make it..i dont have any idea that how can i make it..i am looking for EEG signals for it. but i cant find from any where.can u please tell me from where i can find it? and do i have to use MATLAB EEG toolbox for that signal? can u please show me some data or video or some steps that how can i make 1D cursor?
This is my masters project sir so plz help me about this.
Thnx again for your reply.
Post by mellinger » 30 Jan 2012, 11:08
sonidaman
Post by sonidaman » 30 Jan 2012, 11:41
ok thnx for your reply sir.i will try my best.
Thnx for your help.
