Trial times problem
JoeZhang
Trial times problem
Post by JoeZhang » 09 Jan 2012, 04:20
I am a freshman for using BCI2000,now there is a problem puzzled me a lot.i use the CursorTask application with bci competion II data(self-paced 1s),sample rate 100Hz , 28 channels ,50 samples per channel, 316 trials.I set SampleBlockSize 32 , NumberOfTrials is 40/80/300, but it can be only running 35 trials no matter what NumberOfTrials is and System log show the message"Warning: FilePlaybackADC::Process: Wrapping data around." please help me ,thanks.
Re: Trial times problem
Post by mellinger » 10 Jan 2012, 11:05
you cannot use BCI2000 for replaying such data. Use the OfflineAnalysis tool in order to do data analysis.
