Compilation Problems with VS Express 2010
vladi
Post by vladi » 04 Jan 2012, 08:49
I tryed to follow the instruction on the on quick start guide in order to create a new source module. But if I try to build it with VS 10 I get the following errors and I also get the same errors when I try to rebuild on of the existing modules.
2>C:\BCI2000\src\shared\utils\Expression\ArithmeticExpression.cpp(364): error C2662: 'ArithmeticExpression::StoredPointer::Delete': this-Zeiger kann nicht von 'const ArithmeticExpression::StoredPointer' in 'ArithmeticExpression::StoredPointer &' konvertiert werden
3>LINK : fatal error LNK1104: Datei "..\..\..\frameworks\CoreLib\Debug\BCI2000FrameworkCore.lib" kann nicht geöffnet werden.
I would really appreciate if anybody would have a idea what i could do.
Re: Compilation Problems with VS Express 2010
Post by jawilson » 05 Jan 2012, 11:10
If you previously used VS 2008, you need to create a new solution file using the
BCI2000/build/Make VS10 Project Files.bat
file. I actually often completely delete the build directory completely, and do an SVN checkout just to make sure nothing undesirable is left in that folder.
For the linker error, make sure that the BCI2000Framework* libraries are compiled before anything else. This should happen by default, but you never know with Microsoft products.
Adam
Post by mellinger » 10 Jan 2012, 11:00
The compilation problem has been fixed on SVN. Do an "SVN update", and compile again.
