ahalharbi
Post
by ahalharbi » 21 Nov 2011, 15:25
Dear BCI2000 programmers,
I am trying to run BCI2000 using C++ builder XE2. When I run the program an error massage is appear:
SingleProcessing:Could not connect to operator module.
How can I solve this problem.
I relay need your help.
I am using windows vista
64-bit
Waiting your replay..
Amal Alharbi
Post
by mellinger » 22 Nov 2011, 08:28
C++ Builder cannot be used to build the BCI2000 Operator module. Thus, when building BCI2000 with C++ Builder, the operator module is not built, and will be missing when you try to start up your compiled BCI2000.
In order to get an Operator module, you need to download a binary release (
http://www.bci2000.org/wiki/index.php/B ... on_History), and move both Operator.exe and OperatorLib.dll from the binary release's prog directory into your BCI2000 prog directory.
ahalharbi
Post
by ahalharbi » 22 Nov 2011, 17:39
Thanks Juergen.
I did exactly what u said before but still a have the same problem
any other solution
