Hi
I was just wondering if there is any way to change the frequencies that different stimuli occur for different runs with in the same experiment.
For example, say I want the stimuli to be copied in the order 1 2 3. If I set the frequencies to 8 8 8, each stimulus will occur 8 times in all 3 runs. Is there a way to change it so that in the first run 1 only appears say 2 times but for the other runs it appears 8 times?
Leandra
Changing stimulus frequencies within one run
Re: Changing stimulus frequencies within one run
this is not possible with the current StimulusPresentation module. However, it is possible to automate BCI2000 from the command line, such that it automatically loads a parameter file at startup, and automatically exits on suspend.
Using Operator scripting from the command line, it is possible to write a batch file that automatically starts BCI2000 in different configurations/with different parameter files, in sequence.
For documentation of Operator scripting, and command line parameters, see:
http://www.bci2000.org/wiki/index.php/U ... _Scripting
http://www.bci2000.org/wiki/index.php/U ... ne_Options
For an example how to use this, see the testing batch file at BCI2000/build/buildutils/tests/run_tests.bat.
UCTEEGLab
Thanks for the reply - that sounds just like what I need.
Regards
Leandra
Regards
Leandra
