BCI2000Viewer won't open
ngiri
Post by ngiri » 16 Sep 2021, 05:11
I cannot open the BCI2000 Viewer. When I click on it, my cursor circles for a bit and then goes back to normal, but nothing else happens. Is there anything I can do about this?
Thanks in advance!
Re: BCI2000Viewer won't open
Post by mellinger » 17 Sep 2021, 08:48
BCI2000Viewer works fine for me (x64 release build on 64 bit Windows 10).
Maybe deleting BCI2000Viewer.ini in the BCI2000Viewer directory can fix your issue.
ngiri
Post by ngiri » 20 Sep 2021, 05:18
Thank you for your response. I could not find BCI2000Viewer.ini. My BCI2000Viewer directory (C:\BCI2000.x64\tools\BCI2000Viewer) only contains a BCI2000Viewer.exe and BCI2000Viewer.html file. Is this incorrect?
Post by mellinger » 22 Sep 2021, 07:47
Does the Operator module work if you double-click it?
ngiri
Post by ngiri » 04 Oct 2021, 06:39
Thank you for your reply, I managed to fix the issue by reinstalling Qt and configuring and building the BCI2000 source code from scratch.
