Record for later playback
bci2020
Post by bci2020 » 29 Apr 2019, 15:06
How can I record signal input such that it can be played back? Is there an already compiled and working module for Windows?
Re: Record for later playback
Post by mellinger » 15 May 2019, 09:32
You may use the FilePlayback source module to play back data recorded with any source module. The FilePlayback module is not part of the core distribution, so you will need to download the extended distribution in order to use it.
