emotiv-matlab-BCI2000
mesutmaleki
Post by mesutmaleki » 29 Oct 2016, 14:21
hello
i have emotiv and i want to use it for real time in matlab.
i can not connected it to matlab by emotiv programms. how can i do this by BCI2000?
please help me
Re: emotiv-matlab-BCI2000
Post by pbrunner » 31 Oct 2016, 17:14
Mesutmaleki,
BCI2000 provides a source module for the "Research Edition" of the Emotiv EPOC. Please note that the Emotiv EPOC+ version as well as the non-research edition are not supported.
If you have this type of hardware, please download the latest BCI2000 release version from [1] (including the contributions) or the 32-bit binaries of the latest v3.6 beta version from [2].
First try to get your Emotiv EPOC device to work with BCI2000. For this start the BCI2000Launcher in the prog folder and select the Emotiv.exe as the source module, the DummySignalProcessing as the signal processing module and the DummyApplication as the application module. This should start BCI2000, and after pressing set config, you should see the signals from your Device. You can store data by pressing the start button. The stored data and the parameter of your device are explained on the BCI2000 wiki [3].
To process your data in MATLAB, you can use the MatlabFilter, which is also explained on the BCI2000 wiki [4.
[1] http://www.schalklab.org/research/bci2000/download
[2] http://www.bci2000.org/bbs/viewtopic.php?f=1&t=2955
[3] http://www.bci2000.org/wiki/index.php/C ... ons:Emotiv
[4] http://www.bci2000.org/wiki/index.php/P ... tlabFilter
