Dear pbrunner
when I run the BCI2000 launcher.exe .it said QtGuid4.dll is missing and I have add the Qt bin folder to the system path and it still show the same problem . and when I switch my bci2000 release branch to the trunk , the SVN show "Error : No write-lock in 'C:\bci2000\bci complete\new folder\BCI2000\prog' .And then SVN said Switch Failed.
can you help me fix this problem ? thank you
the question about connecting the bci2000 to the ardunio
summersun
Re: the question about connecting the bci2000 to the ardunio
Summersun,
please use the SVN trunk [1], as this will be come the release shortly. This should fix your issues.
Please use the instructions posted in the BCI2000 v3.6 beta testing thread to download and compile the source code from the
http://www.bci2000.org/svn/trunk repository.
