Configuring 2D cursor Task: need vertical cursor
Goxothorn
Post by Goxothorn » 27 May 2014, 19:07
In my master thesis project I'm using the 2D cursor task. In this task, by default the cursor is going from left to right but I would need it to go from down to up. I checked how I could do that in the setting and i find how to modify the starting position of the cursor but not how to change its course.
Thank you for your help.
Re: Configuring 2D cursor Task: need vertical cursor
Post by boulay » 27 May 2014, 21:56
It depends on the version of the application you're using. One way I can imagine doing it with the version I have is to make my first control signal a constant (i.e. 1) and the second control signal will be your brain signal.
