I have downloaded the latest version of BCI code. The version that I downloaded is 3654. But, when I compiled the program in the environment of Borland C++ Builder 6.0, it could not pass the compilation. It came out many errors as follows:
Build
[C++ Error] Runnable.h(84): E2108 Improper use of typedef 'T1'
[C++ Error] Runnable.h(84): E2299 Cannot generate template specialization from 'FunctionCall<T>'
[C++ Error] Runnable.h(92): E2428 Templates must be classes or functions
[C++ Error] Runnable.h(93): E2108 Improper use of typedef 'T1'
[C++ Error] Runnable.h(93): E2293 ) expected
[C++ Error] Runnable.h(102): E2299 Cannot generate template specialization from 'FunctionCall<T>'
[C++ Error] Runnable.h(113): E2428 Templates must be classes or functions
[C++ Error] Runnable.h(115): E2238 Multiple declaration for 'FunctionCall<R>'
[C++ Error] Runnable.h(67): E2344 Earlier declaration of 'FunctionCall<R>'
[C++ Error] Runnable.h(123): E2108 Improper use of typedef 'T1'
[C++ Error] Runnable.h(123): E2299 Cannot generate template specialization from 'FunctionCall<R>'
[C++ Error] Runnable.h(131): E2428 Templates must be classes or functions
[C++ Error] Runnable.h(132): E2108 Improper use of typedef 'T1'
[C++ Error] Runnable.h(132): E2293 ) expected
[C++ Error] Runnable.h(141): E2299 Cannot generate template specialization from 'FunctionCall<R>'
[C++ Error] Runnable.h(152): E2428 Templates must be classes or functions
[C++ Error] Runnable.h(163): E2108 Improper use of typedef 'C'
[C++ Error] Runnable.h(163): E2188 Expression syntax
[C++ Error] Runnable.h(171): E2299 Cannot generate template specialization from 'MemberCall<T>'
[C++ Error] Runnable.h(181): E2428 Templates must be classes or functions
[C++ Error] Runnable.h(182): E2108 Improper use of typedef 'C'
[C++ Error] Runnable.h(182): E2188 Expression syntax
[C++ Error] Runnable.h(192): E2299 Cannot generate template specialization from 'MemberCall<T>'
[C++ Error] Runnable.h(204): E2428 Templates must be classes or functions
[C++ Error] Runnable.h(206): E2108 Improper use of typedef 'C'
[C++ Error] Runnable.h(206): E2228 Too many error or warning messages
These errors are come from the compilation of the BCBProject file: P3Speller. The file's path is: src\core\Application\P3Speller.
What I want to ask is why the file can not pass the compilation by using Borland C++ Builder 6.0? Is the compiler version is too low? If so, What version of the software should I use? And what's the problem if that's not the problem of version?
Thanks very much!
Yang Chengjie
2011-11-9
How to compile the BCI code?
Re: How to compile the BCI code?
Unfortunately, Borland C++ Builder 6 is not able to compile that code. However, it compiles fine under C++ Builder 2010.
You might consider switching to Microsoft VisualStudio Express, which is available for free from Microsoft's web site.
