Emotiv amd BCI2000
Kalvin
Re: Emotiv amd BCI2000
Post by Kalvin » 14 Sep 2011, 14:02
Negative to both - no EPOC software running, and the EPOC does work with its own software. And it is a research edition, of course.
griffin.milsap
Post by griffin.milsap » 15 Sep 2011, 15:35
Kalvin,
It would seem that the Emotiv SDK cannot connect to your headset. Is the dongle plugged in and the headset turned on?
Can you give any more specifics about your setup and system? Are you trying to work through a VM?
-Griff
Kalvin
Post by Kalvin » 15 Sep 2011, 20:15
I'm currently not at the system, but I think that the basic specifications are 1-2GB RAM and a 3Ghz CPU (single core).
Kalvin
Post by Kalvin » 16 Sep 2011, 03:30
3.2Ghz Pentium 4
1GB RAm
WinXP Professional SP3
Btw, I installed BCI2000Contrib.exe over the normal installation. Could this be a reason?
Kalvin
Post by Kalvin » 16 Sep 2011, 04:56
I just switched to my Thinkpad notebook with a fresh install of the Contrib package, and could run the calibration with the EPOC now.
Intel Core 2 Duo P8400 2.26Ghz
3GB RAM (available to XP)
I am currently searching for the reason for this error (after entering the letter Q in the second calibration session) - it might be necessary to change the session run number:
2011-09-16T10:30:17 - P3SpellerTask::Process: unhandled exception class std::__non_rtti_object (Access violation - no RTTI data!),
terminating Application module.
Post by mellinger » 20 Sep 2011, 13:02
This error is due to a bug that has been fixed since the last binary distribution came out
(http://www.bci2000.org/tracproj/changeset/3510).
You may avoid the bug by restarting BCI2000 each time you aborted a run, i.e. restart BCI2000 each time after clicking "Suspend" in the Operator module. When a run finishes by itself, no restart is necessary.
Kalvin
Post by Kalvin » 21 Sep 2011, 03:12
Ok, thanks!
ateam
Post by ateam » 01 Apr 2012, 01:47
When I use the BCI2000Launcher I select Signal Source:Emotiv Signal Processing: MatlabSignalProcessing and Application: CursorTask. I get an error
SpatialFiler::Destructor:MatlabFilter::Destructor:Could not load library:libeng:
The specified module could not be found.
I do have Matlab. I have 2010a.
I used the batch file CursorTask_SignalGenerator I changed the code like so
cd ..\prog
start operator.exe ^
--Title %~n0 ^
--OnConnect "-LOAD PARAMETERFILE ..\parms\examples\CursorTask_Emotiv.prm"
start Emotiv.exe 127.0.0.1
start ARSignalProcessing.exe 127.0.0.1
start CursorTask.exe 127.0.0.1
cd ..
I still seem to get the same screen. I changed the parms just as it asked in
http://www.bci2000.org/wiki/index.php/C ... ons:Emotiv
When I go through the cursor task, but when I load the dat file in to BCI2000 offline Analysis I get
Invalid trial change condition specified. I have my Trial change condition as specified here
http://www.bci2000.org/wiki/index.php/U ... hm_Session
If I try and run the sample dat it will run with no issues.
I have been using it for a while. I am running windows vista 32bit. I have spent all day going thru the tutorials and still could not analyze the signals.
Please respond
Post by mellinger » 04 Apr 2012, 05:40
Please see the following page for information about troubleshooting issues with the Matlab filter:
http://www.bci2000.org/wiki/index.php/P ... leshooting
