starting BCI2000
Gagandeep kaur
starting BCI2000
Post by Gagandeep kaur » 09 Nov 2008, 12:47
hi grev,
i have just installed bci2000 on my machine and i need to know that how to get started... i have read the getting started page but i could not find that how can i use it offline... are there any stored signals available using which i can see that how it works from signal extraction to signal filtering ... till command signal generation :?
regards
gagan
TooT
Re: starting BCI2000
Post by TooT » 29 Apr 2011, 04:33
I have the same problem :(
I'm sure the user name and password I use are correct!
Have you solved the problem?? and how?!
Post by mellinger » 29 Apr 2011, 07:31
when you created a user account and password on the BBS, you cannot use that to download BCI2000.
Please go to http://www.bci2000.org/GPL/ in order to get an account that you can use to download BCI2000.
After downloading, go to http://www.bci2000.org/wiki/index.php/U ... I2000_Tour in order to learn about how to use BCI2000.
