i wrote some changes to the P3Speller, now i want to compile my whole programm as release. As long as i do this on my computer there is no problem but when i try to use the programm on another computer there are some MSVCP90.DLL, MSVCR90.DLL files (and their debug versions) missing.
I tried to change the compilerflag for the runtimelibrary from /MD to /MT, so that the files run out of a static run time library.
Now, i get the message, that i can't include those files twice, LNK2005. Functions are already defined in LIBCMT.lib.
Does anyone know a solution?
Of course here are my settings: Win XP, MSVC++ 2008 Profesional, BCI2000 V3
Thanks for reading,
Stefan
Creating a Release Version of BCI
Re: Creating a Release Version of BCI
Hi Stefan,
we changed compiler flags for BCI2000. Static linking against MSVC runtime libraries is now the default. If you update your BCI2000 source code to the current SVN version, re-create the BCI2000 solution file via CMake, and do a re-build of the solution, then your problem should be solved.
