Mat to gdf,edt,bci2000dat
eelamin
Post by eelamin » 19 Jun 2010, 09:08
Hello
I am experiencing problem in converting eeg signal in the format .mat
into any format that supported by the bci2000 offline analysis toolbox
I will be pleased if someone help me
Elgasim
Post by mellinger » 21 Jun 2010, 06:46
In order to save data as a BCI2000 data file, you will need to provide parameter and state (event, trigger) information in a suitable format, and then use the save_bcidat mex file to write out the file.
Could you give more information about what you want to do?
--Juergen
eelamin
Post by eelamin » 24 Jun 2010, 11:51
can you tell me more about the parameters and triger events and how can i add it to the data?
Post by mellinger » 25 Jun 2010, 08:38
What kind of data do you have? Sensorimotor rhythms, or evoked potentials?
eelamin
Post by eelamin » 25 Jun 2010, 11:07
My data is berlin bci competition IV data set one "(seven subjects imagining three types of movement right hand, left hand, and leg movement) utilizing motor imagery
Post by mellinger » 25 Jun 2010, 12:33
You will need to specify target conditions for each point in time. Create a struct variable "states" with a member "StimulusCode" in Matlab, which is a N x 1 matrix. It should have as many entries as there are samples in the data set. For each point in time, assign a StimulusCode of 0, 1, 2, or 3, depending on which imagination was performed at that point in time:
  • 0 when no imagination was performed,
    1 when right hand movement was imagined,
    2 during left hand imagination,
    3 during leg movement imagination.
In addition, you need to specify the sampling rate as a BCI2000 parameter. In Matlab, create a struct variable "parameters", with a member "SamplingRate", which is itself a struct, with the following fields (replace the number in the Value field with the actual sampling rate):
>> parameters.SamplingRate
ans =
         Section: 'Source'
            Type: 'int'
    DefaultValue: '256Hz'
        LowRange: '1'
       HighRange: ''
         Comment: 'sample rate'
           Value: {'600'}
    NumericValue: 600
Assuming that the EEG signal is contained in a variable called "signal" with dimensions channels x samples, run the following command:
save_bcidat('myfile.dat', signal, states, parameters);
The resulting file should be suited for use with the BCI2000 OfflineAnalysis program.
eelamin
Post by eelamin » 01 Jul 2010, 02:50
I had constructed the structures states,parameters with their substructures stimuluscode, samplingrate respectively but,when using the command:
returns:
??? Error using ==> save_bcidat
Parameter values must be strings or cell arrays of strings.
and when i convert the parameters.sampling rate into cell using the command:
struct2cell
it returns:
Could not access string field "Section".
would yu help me please
Post by mellinger » 01 Jul 2010, 08:33
Did you enclose the parameter value into curly braces as in
parameters.SamplingRate.Value = {'600‘}
eelamin
Post by eelamin » 01 Jul 2010, 08:46
yes i wrote the code:
SamplingRate= struct('Section','Source','Type','int','DefaultValue','256Hz','LowRange','1','HighRange','','Comment','sample rate','Value',{'100'},'NumericValue','100');
eelamin
Post by eelamin » 02 Jul 2010, 00:50
but, the problem is still running
Post by mellinger » 02 Jul 2010, 08:29
When you write
what does the output look like?
eelamin
Post by eelamin » 02 Jul 2010, 17:25
the code looks like:
ans =
Section: 'Source'
Type: 'int16'
LowRange: '1'
HighRange: ''
Value: '{100}'
NumericValue: '100'
and when using the command struct2cell it looks like;
ans =
'Source'
'int16'
'256Hz'
'1'
'sample rate'
'{100}'
'100'
Post by mellinger » 05 Jul 2010, 08:27
Look at the curly braces in the "Value" field. The field should read {'100'} but it reads '{100}'. Once you correct this, it should work.
