compiling bci2000 with sigfried
naderp
Post by naderp » 18 Mar 2010, 16:09
I've followed instructions for compiling bci2000 with sigfried at http://www.bci2000.org/wiki/index.php/C ... iedSigProc but am not finding the expected output. The .ini and .dll files are in the parent directory and the .exe file is nowhere to be found.
I'm using C++ Builder 2010... could that be the problem?
Nader
Post by mellinger » 19 Mar 2010, 12:49
Nader,
when using C++ Builder 2010, you cannot build BCI2000 from the command line as suggested on the wiki.
Rather, you need to manually copy the sigfried.ini and sigfried.dll files to the BCI2000/prog directory. The linker should place the executable in the BCI2000/prog directory as well.
