Error in Matlab with offline analysis
EliGC
Post by EliGC » 01 Feb 2010, 16:12
Hello!!
I have problems trying to read the data with the offline GUI. I have everything in the save directory, including the function load_bci and the .data files, but I´ve continued having the same error:;
Error using ==> load_bcidat
Out of memory when reading file name.
Error in ==> OfflineAnalysis>btnAdd_Callback at 791
[tmpSig, tmpStates, tmpParams,tmpNumSamps] =load_bcidat(fp, [1 1])
PS: I have the last BCI2000 version and Matlab 2009.
Eli
Post by mellinger » 02 Feb 2010, 11:39
Eliana,
when I try the offline analysis tool under Matlab R2009b, loading BCI2000 example files, it works as expected.
When you execute "load_bcidat -v" from the Matlab command line, what is the output?
--Juergen
EliGC
Post by EliGC » 05 Feb 2010, 10:16
When I try to execute load_bcidat.m Matlab says:
- C:\...000\tools\OfflineAnalysis\load_bcidat.m is not found in the current directory or on the MATLAB path.
But the function load_bcidat, as I told you is in the same directory of the offline analysis GUI.
The other thing is that when I tried to use load_bcidat.m with other GUIs (that we programmed), I didn´t have any problem.
Thank you so much,
Eliana
Post by mellinger » 05 Feb 2010, 10:55
Eliana,
load_bcidat is a mex file, not a .m file. There is an associated .m file to support Matlab help, but that is not present in the Offline Analysis directory.
So, please execute the following from the Offline Analysis directory:
load_bcidat -v
