Can 64-bit MATLAB be used with BCI2000?
trentb
Post by trentb » 02 Nov 2009, 22:36
When I try to run MatlabSignalProcessing through the BCI2000 Launcher interface, I receive the following errors:
11/2/2009 10:27:43 PM - MatlabFilter::Constructor: Could not load library libeng:
11/2/2009 10:27:43 PM - MatlabFilter::Constructor: Could not connect to Matlab engine. Please make sure that Matlab is available on your machine.
Through some debugging, I can confirm that libeng.dll is being found in "C:\Program Files\MATLAB\R2007a\bin\win64". I surmise that the problem is that libeng.dll is a 64-bit DLL instead of a 32-bit DLL. Is there any workaround to this problem without installing a 32-bit version of MATLAB?
-Trent
64 bit
Post by gschalk » 05 Nov 2009, 08:41
I presume you could recompile the MatlabSignalProcessing with the 64 bit libraries. This should work. I do not see any other workaround.
trentb
Re: 64 bit
Post by trentb » 17 Nov 2009, 17:10
I have been unsuccessful in invoking the 64-bit MATLAB engine, and believe I know the reason. The 64-bit libraries provided by MATLAB are only for Microsoft Visual C++, not Borland C++. Borland is not supported by the 64-bit version of MATLAB. I will revert back to a 32-bit system.
-Trent
32-bit
Post by gschalk » 19 Nov 2009, 10:29
Trent,
At this point, it's probably wise to stay with XP-32. Just so you know, BCI2000 v3.0, which will be released next month and is already available on SVN, will also support VisualStudio.
Best,
trentb
v3.0 Operator Build Errors
Post by trentb » 20 Nov 2009, 11:38
Gerv,
Thanks for the advice. Version 3.0 builds without error until it gets to VisDisplayGraph.cpp of Operator. I get the following errors related to the limits class. I have tried to include limits provided by QT, but I still get errors. Any advice on resolving these errors?
1>VisDisplayGraph.cpp
1>C:\BCI2000_v3.0\src\shared\gui\SignalDisplay.h(332) : warning C4099: 'SignalDisplay::PaintInfo' : type name first seen using 'class' now seen using 'struct'
1> C:\BCI2000_v3.0\src\shared\gui\SignalDisplay.h(276) : see declaration of 'SignalDisplay::PaintInfo'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2065: 'numeric_limits' : undeclared identifier
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2275: 'size_t' : illegal use of this type as an expression
1> predefined C++ types (compiler internal)(19) : see declaration of 'size_t'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : warning C4003: not enough actual parameters for macro 'max'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2589: '(' : illegal token on right side of '::'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(95) : error C2059: syntax error : '::'
-Trent
Post by mellinger » 20 Nov 2009, 12:29
Trent,
I committed a change that should fix the compilation error.
trentb
Re: v3.0 Operator Build Errors
Post by trentb » 20 Nov 2009, 12:49
Juergen,
Thanks for the change; however, I now get the following errors:
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(97) : warning C4003: not enough actual parameters for macro 'max'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(97) : error C2589: '(' : illegal token on right side of '::'
1>..\..\..\..\src\core\Operator\OperatorQt\VisDisplayGraph.cpp(97) : error C2059: syntax error : '::'
I don't know if this will make any difference, but I am using Visual C++ 2008.
-Trent
trentb
Fixed max error
Post by trentb » 20 Nov 2009, 15:31
Fixed it. The problem was that the compiler was getting "confused" between the macro max and the class member max defined in limits. I added the line
#define NOMINMAX
before every
#include <Windows.h>
and
#include "windows.h"
statement to disable the macro max. Surprisingly calls to the macros max and min do not return an error. I guess its able to find a definition of max and min somewhere without getting confused with the class member max in limits.
Trent
trentb
Post by trentb » 20 Nov 2009, 22:21
Unfortunately I still cannot invoke the 64-bit Matlab engine from a Visual C++ build. I do not think this is a BCI200 problem. I think it is a 64-bit Matlab problem.
-Trent
trentb
Resolution
Post by trentb » 25 Nov 2009, 22:07
I installed 32-bit MATLAB on my Windows XP 64 system. I then ran BCI2000 (the version from 'trunk', not the soon-to-be-released 3.0) with the MATLAB filter without any problem.
-Trent
