Hello everyone!
I have written a custom bci2000 module that acts similarly as the signalgenerator. Instead of generating random data, it outputs pre-recorded eeg data from a file. So far the module works as intended, the only problem is that if i check the visualize option for this module (and for the matlab filter which is a simple IIR bandpass) i dont get the option "more/fewer samples" when i right-click the visualization window.
Do i need to implement anything for the options to appear?
Also, how can i adjust the maximum/minimum number ranges in the visualization? The reduce/enlarge only seem to act on specific ranges and at some point you cant increase or decrease the zoom.
Thanks in advance
Alex
Filter output visualization
Alex,
in recent versions of BCI2000, you should always get the "more/fewer samples" option. If it is missing, check the operator module's build date under Help->About.
The reduce/enlarge commands are intentionally range restricted to avoid user confusion. To give BCI2000 a hint regarding the proper range, set the filter output's signal properties from the filter's Preflight() function. As an example, the following code will set the output to unit range:
For the Matlab filter, there is currently no way to specify an output range.
Rather, the output range is always assumed to be between +1 und -1.
void MyFilter::Preflight( const SignalProperties& Input, SignalProperties& Output ) const
Output.ValueUnit()
.SetOffset(0)
.SetGain(1)
.SetRawMin(-1)
.SetRawMax(1);
