I've been using BCI2000 for a couple month now on the computer at my univeristy, and recently decided to install it on my home computer.
I have downloaded the source code with TortoiseSVN and I compiled the "project group". Everythng went well, but the Launcher gives me an error message:
"Error reading ActionManager1->StyleName: Property StyleName does not exist."
I tried recompiling just the launcher, but when I open the project, it says that it cannot create the form because of an inexisting ActionManager1->StyleName.
If I choose to ignore the error, I can compile it but without any changes to this first problem. If I choose to not ignore the error, then the form is not loaded...
I tried finding where the code calls this StyleName field, but it doesn't.
I have no idea where this is coming from.
I have the latest revision.
Thanks in advance
Jeremy, student @University of Geneva
BCI Launcher error
jawilson
I wrote and maintain this program. The problem is due to an incompatibility between Borland 6 and Borland 2007, which introduces a component called XPStyleActnCtrls automatically into the code. After doing this, it will compile with borland 2007, but give this error in borland 6.
I am going to change the program so that it does not depend on this component at all. I will post here again within a few hours when it is working.
Adam
Adam
