Problem with RJB?
wolfgray
Problem with RJB?
Post by wolfgray » 08 Feb 2005, 15:16
Hey all.
Using the latest version of BCI2000 from the CVS,
I have an intresting problem with rjb.
For refrence: I'm running the random number operator as my eeg source, the ar singal proc module for signal, and rjb unmodified (just complied) for the application. and using BCI Batch to automate the loading.
Everything comes up fine and when I click suspend rjb appears to work.
The first trial goes without a problem, then the system sets up for the second trial of the run and the target appears, the cursor appears but the cursor does not move. Suspending and restarting the trail does not make any effect. All trials at this point result in the cursor not moving. Reloading the configuration file and using 'set config' again also dosen't help. The cursor still dosen't move.
Anyone else seen this error?
-Luke
GSU Brainlab
RJB problem ...
Post by gschalk » 08 Feb 2005, 21:57
Hey Luke,
You are probably adapting on the X dimension as well as on the Y dimension. Check your Statistics->XTrendControl parameter and turn it off.
Let us know if this helps,
The Gerv
wolfgray
Post by wolfgray » 10 Feb 2005, 13:43
Yep that fixed it.
-Luke
