Error (0xc0000005) using LSL Sourse
cmontilla
Post by cmontilla » 09 Sep 2026, 05:07
I try to use LSL Source of BCI2000 and despite having the LSL stream active:
2026-09-09T10:56:43.307 - BCI2000 Started.
2026-09-09T10:56:43.402 - SignalSource: Waiting for configuration ...
2026-09-09T10:56:43.429 - SignalProcessing: Waiting for configuration ...
2026-09-09T10:56:43.705 - Application: Waiting for configuration ...
2026-09-09T10:57:29.883 - Operator set configuration.
2026-09-09T10:57:29.885 - SignalSource: DataIOFilter::AutoConfig: LSLADC::AutoConfig:
Now waiting for an EEG stream...
2026-09-09T10:57:31.901 - SignalSource error:
Unhandled Win32 exception of type ACCESS_VIOLATION (0xc0000005)
Terminating LSLSource module.
2026-09-09T10:57:32.913 - SignalSource error:
The stream name is the same "EEG"
Thanks for your support.
Re: Error (0xc0000005) using LSL Sourse
Post by mellinger » 09 Sep 2026, 06:16
Hi, thanks for reporting this.
There was a bug in older versions of the LSLSource. Which version of BCI2000 are you using?
cmontilla
Post by cmontilla » 09 Sep 2026, 08:04
I am using version 3.6.7385
Thanks.
Post by mellinger » 09 Sep 2026, 10:24
The current version of BCI2000 is 3.6.9546. A couple of issues has been fixed in the LSLSource since.
Unfortunately, the latest BCI2000 installer is version 3.6.7385. To use a version newer than 3.6.7385, you will need to download and build BCI2000 from source as described here:
cmontilla
Post by cmontilla » 11 Sep 2026, 05:41
I am trying to do this, and I am getting two errors during the BCI2000 compilation due to the file "cannot open input file 'C:\BCI2000.x64\\prog\SignalSharingClientLib.lib'" in Visual Studio.
I am not sure if this affects P300 applications...
Thanks!!
Post by mellinger » 12 Sep 2026, 07:11
Sorry for the issue, and thanks for reporting.
I fixed the build order and hope it works for you after updating from SVN.
cmontilla
Post by cmontilla » 14 Sep 2026, 04:04
Yes!!! Works perfect, thanks for all!!
Post by mellinger » 14 Sep 2026, 07:40
Sure, and thanks for the feedback.
