I have compiled the driver for the Emotiv for the BCI2000 platform as described.....http://www.bci2000.org/wiki/index.php/P ... tart_Guide.
I downloaded the BCI2000 source code with tortoiseSVN
I then used CMake2.8 to compile a project file
and then Built BCI2000 and Drivers using Visual C++ 2010 Express...
All as described!!!!
The Emotiv appeared in the other section of the BCI Launcher. The Launcher is not receiving any data packages from the device and the system remains idle, with no status..
I am also getting the following error when I attempt to run any test.bat etc... opencv_core220.dll is missing.......
I downloaded the file: vcredist_x86.exe.... and it makes no different, it keeps telling me that the program may have not installed correctly?????
What am I doing wrong?
Thanks a million
Tiernan
