Problem compiling the Emotiv module
hansson
Post by hansson » 19 Apr 2011, 07:02
Hi
I'm having issues compiling the Emotiv Signal Source module. The compiler gives different errors about it (if you are interested I pasted the error list here: clicky). I have tried making modifications to the MODTYPE definition in GenericFilter.h and while the compilation errors disappear the module still does not work.
I'm using:
Windows 7 64bit
Visual Studio 2008
Cmake 2.8.1 but also tried newest
I generate VS solution files by running Make VS2008 Project Files.bat and then open up the Emotiv one and compile from there. I have also attempted to compile everything (selecting yes on all options in the bat file and opening up the BCI2000.sln solution file) but the end result is the same.
Any pointers would be appreciated.
Re: Problem compiling the Emotiv module
Post by mellinger » 19 Apr 2011, 08:50
it appears you have a broken version of the BCI2000 source code. Please update your SVN working copy to the latest version -- that should fix it.
